taylor0987
- September 20, 2005
- Baltimore, MD
- '92 Navajo LX
Hi, I have a 92 Navajo 4wd with the A4LD transmission. When it's cold it slips, takes 30 seconds or so to get into gear, or it will sometimes go into gear when I rev the engine. It has this problem regardless of what gear I select (R, overdrive, D, 2, or 1) When it's warmed up it behaves normally except that it will never shift from 3 to overdrive.
The fluid level is correct. I changed the fluid and the filter. It did have a delayed 1-2 shift and I already pulled the governor and cleaned it. That seemed to help some. I have not tried adjusting the bands or much else of anything. I have read alot here on the forum but I'm not sure where to start given my symptoms.
I do not know much else about the history of this vehicle--I bought it for cheap with the engine blown and swapped in a junkyard engine, and have had these problems since I got it running.
Thank you.
Thank you.
