scrivyscriv
- June 1, 2008
- Memphis, TN
- 02 Ranger XLT 2WD auto
I noticed my temp gage going to the far range of NORMAL and then slowly returning to its regular spot about a month ago, so I changed the thermostat. Replaced it with an AutoZone Valucraft $4.00 part, and it seemed okay for a few days, but then started acting up again.
It warms up, sits on the 'N' or 'O' of NORMAL, then will climb to the far end - but not as far as it did before I changed the thermostat - and quickly return back to the 'N' or 'O' it lives on. The gage most often, but not always, rises when I'm not moving, and will return as soon as I rev the engine.
Heat was blowing hot until I changed the thermostat, now it blows a mediocre warm.
Coolant is about 70/30 antifreeze/water.
Squeezed the upper radiator hose with the engine running and felt pressure build up.
I've seen similar threads but nothing that describes my Explorer.
Temp sensor?
Fan clutch?
Thanks for any help.
Temp sensor?
Fan clutch?
