hatched91
- October 2, 2005
- godfrey, Illinois
- 1997 sport ohv 5spd
like the title says, my 93 x won't go into reverse. it's a 5spd out of a 93 navajo. i picked it up from the junkyard and it went into reverse there. i brought it home and put it in my truck when converting it from an auto to a stick. when i first put in the stick, i had alignment problems with the stick going into the tranny linkage, but i found out on here that i need to have a "box" shape for the stick to sit down in. this fixed the problem to where all the gears now align and go into gear, except reverse. when i try to engauge reverse, i push over to the right and then it won't go back. i tried rolling the truck a little, putting it in other gears first but it still refuses to physically move backwards when moved all the way to the right. i don't believe that reverse this bad, but i suppose anything is a possibility. any suggestions on what to try?
