Marked off the list:
Picked up the new lug nuts (longer so its easier to get them off because of the thick mounting flange in the rim)
New Group 65 AGM battery.
Got the passenger side body mount done (had to cut those front mounts off to reinforce the frame rails)
And i have been having one hell of a time with battery cables, while using those cheap-o battery terminals, the ones you cut and clamp the cable to the terminal. Mine were horribly corroded and when i would jump start the truck (shot used battery) the negitive able would start to glow LOL from high resistance.
So using the BIG 3G upgrade that the BKO guys do,i replaced the positive and negitive terminals with marine style stud clamps and upgraded all the main wires (minus the charge wire, I will do that one this weekend) with 0 gauge welding cable, and High Voltage/High Amperage cables and (thanks to
@gmanpaint for showing be the cable clamp tool!) cable lugs.
Battery/Starter cables
Not liking the idea of cutting away a small section of insulation on the ground cable, to ground the frame, i replaced that section on cable with its own short section, the above lug will bolt to the frame, and then to the engine block where that factory bolt is.
You can see above the other end of the frame grounding cable and engine grounding cable. used the factory bolt and also the factory bolt "keeper" so if anyone does this upgrade try and save the little keeper to reuse.
Here is the starter side of the cable, starter power wire and the starter trigger.
my rig still has the factory setup at the starter solenoid and is still in good condition so i cut the start trigger wire about 6 inches from the solenoid and installed a WeatherPack connector.
