iwantacelica
- September 14, 2006
- New Orleans area
- 1994 XLT 4x4 Ranger
hi all...my Ranger is having some trouble. I was changing spark plugs/wires today and I noticed two things. First, there is a pretty sizeable vacuum leak on the snorkel, in between the AFM and the TB. On the underside of the intake snorkel, there is a spot that looks like it is worn away, just in front of the TB. Second, if you look at the airbox, there are two nipples on top. These are for the thin plastic vacuum lines. One of those lines was split. If you follow those vacuum lines along the firewall, one of them runs into a T fitting. Out the other side of that T fitting is where the break is, near the transmission fluid dipstick. I am not sure what that goes to.
Obviously I know that these will cause problems, but exactly what kind of problems would a vacuum leak this big cause?
