MythX
- January 3, 2012
- Colorado Springs, CO
- '04 Explorer EB
When I picked up this truck, the best I could get is 3 wheel drive. Sounds cool, but really isn't. BTW, it's mostly stock, the only mod I can tell it has is the manual hub conversion and some aftermarket shocks, but no lift.
It's the passenger side that won't engage, and what I noticed is that the axle shaft just doesn't extend far enough to reach the hub. I can pull it out then it works.....for a little while before it works its way back in. There's nothing holding it at that position. I noticed that the c-clip is missing (as well as that splined washer behind it), however I'm not sure that's the issue since the drivers side works fine and although it has the c-clip, it's missing that washer as well and the clip doesn't seem to be what's holding it out.
I put the clip on the passenger side, and like I thought it doesn't help. I have a splined washer to put on it, but am not sure I should since it would be spinning up against the spindle. I'm hoping it's not an issue deeper in the axle (such as transfer case).
Any suggestions before I button it back up for the week?
Thanks
Thanks
