I have a set of discontinued rcd coil overs and brackets to get rid of torsion bars. They are ment to be used with their 5" kit but would work on a 4" superlifted truck.
The coil overs are known to be a weak point in the lift kit and have a tendency to brake. 1 has already been replaced. They have eibach 850 lb springs installed. They are a little rusty. I would only run these shocks until you can afford to upgrade to a better coil over and limit strap setup.
You will still need some plate to stiffen up the shock bucket and a little hardware to finish the install. Like I said earlier in the post USE THESE SHOCKS AT YOUR OWN RISK. $300 + shipping
