- June 17, 2004
- Knoxville, TN
- 98 Limited AWD 302
Hey,
I'm bringing this post back because someone referred me to it for my passenger side window that was not operating. I utilized the original post and it worked great but I took it to the poster's next level and removed the armature for cleaning. He was right - there was to much chunk in there to make me comfortable for leaving it there.
Anyway, got a perplexing problem because I'm not electrically inclined. After wrestling with the brushes and springs for a while I finally got it done and the window operates beautifully except that up is down now and down is up?? From the switch on the armrest when I press the up button the window goes down and when I press the down button the window goes up. Obviously I missing something in putting back together an electric motor. It sure seems straight forward - remove armature from housing, clean, spring load your brushes and return armature. Any ideas?
I don't know what was changed in the motor, but the easiest way to switch that is to swap the two wires on the back of the switch. Check the other windows, and the right switch too(RF). The individual switch wires are relatively easy to remove and replace. Pull the windows fuse first though.
The wires go into the large connector on the back of the switch. It takes just a tiny screwdriver to get those terminals out.
