97 Brake Pad Replacement | Ford Explorer Forums - Serious Explorations
dwk55
Schenectady, NY
97 Mountaineer
To get at the brake pads, do the caliper slide bolts need to be removed, or can the entire caliper bracket assembly be removed (by unscrewing the caliper anchor plate bolts)?
I saw that the caliper is bolted onto a plate and that plate is bolted on to the main wheel assembly.
If it matters this is a awd v8.
Thanks
The whole caliper will come off and doesn't need to be diassembled. But I would pull the slide pins anyway and make sure they have enough grease on them.
You need only to unbolt the caliper from the bracket (aka saddle).
Anyone got a picture of the Slide Pins? I get confuse what those are. Also, somebody suggested checking the spring on the brakes so they aren't loose. I don't remember seeing the springs when I changed my brake pads. Where are they suppose to be located?
