JoelF
- April 29, 2001
- Points
- Syracuse,NY
- 1998 Explorer XLT
I have a '98 XLT SOHC.
When in "Auto Mode" 4wd with the Control Trac system, it attempts to engage/disengage on dry pavement under acceleration. It makes all kinds of banging and grinding sounds due to the fact that that's it's engaging on dry pavement, which makes sense.
I've had it to the dealer twice for this problem already under warranty. One time they (supposedly) fixed a bad wiring connection and replaced the actuator, I'm assuming they're talking about the engagement motor.
Another time they said it was bad transfer case fluid and they changed it then told me that it needs changing every 15-20k miles because it wears out. Well, the problem is back and changing the fluid didn't fix it.
I would like to fix the damn thing myself but I don't have enough info on the transfer case system itself.
Has anyone had the same problem or similar symptoms? Is there a way to disable this setting and run as close to possible to 2wd only engaging 4wd when I need it by selecting 4H or 4L?
Thanks...Joel
Thanks...Joel
