IndyJonesNYS
- September 3, 2012
- NY
- 2004 Ford Explorer EB
I have a 2004 Eddie Bauer with the 4.6 V8 with 76k miles and the a/c recently started blowing hot air, the a/c clutch is also not engaging with the a/c turned on, I've checked (and also tried jumping the low side a/c switch with a paperclip on the passenger side fenderwell) all the fuses and relay 52 (located on the drivers side fenderwell) in the Owners manual by replacing it and still the a/c clutch will not engage. I've attached a can of r134 to the low side pressure port with a gauge and the pressure is high (obviously because it's off) and still no outcome. I am at a loss here as the 2 relays are good and so is the low pressure switch. I've even checked the connections under the vehicle and on the compressor and clutch and still not able to get the clutch to fire. The system also has no leaks and I have a can of freon ready to put in I just need advice to carefully engage the clutch one final time to recharge the system... any advice other than having a dealer rake me through 500 bucks would greatly be appreciated.
