ddaniel58
- September 30, 2013
- Frankfort, Kentucky
- 2004 Ford Explorer
I'm so happy to find this site. I've got a 2004 Explorer Eddie Bauer that I just love and do all the work to that I can. About 50% of the time I get stumped and need help maybe this site will be better than most of the knuckleheads I get advice from. On to my problem My A/C compressor has shutdown I'm Fairly convinced that the compressor is good it's only two years old and I can apply 12 volts to the clutch and it kicks in and supplies cold air. I have checked both the cycling pressure switch and high pressure switch they both are providing ground. The schematic says that the switches are wired to the PCM and the PCM provides the ground for the A/C clutch relay. If I pull my A/C Clutch relay and apply voltage to pin 5 my clutch still doesn't pull in nor do I get voltage at the clutch. Is there anything else between the relay and the clutch? My relay bench tests OK. How can I check it while its plugged in?
Any and all help will be appreciated!
