thor1701
- April 24, 2007
- fresno ca
- 96 EB
ok, i got my truck a little over a year ago....the ac never worked, i was not told what was wrong with it, just figured no r-134a in it, so i didn't mess with it cuz at the time i didn't have the money, anyways about a few months ago i started to hear this really loud kind of grinding noise....found out it was the bearings in my compressor clutch, i did not know jack about replacing the clutch, i even posted hear looking for help.....not 1 reply......so i bought a shorter belt and just bypassed the thing, i figured i would replace the compressor when i had the money, so got a used one off ebay that was said to be fully working and tested........so i pull the old one off the truck, come to find out there was a little refrigerant left in it...so put the new one on and whatnot....bought me a can of "EZ Chill R-134a Refill with Oil, and Leak Sealer (12 oz.) by Interdynamics " at walmart, it did not come with a hose, but i already had a hose with a gauge on it....so turned the truck on, turned the a/c on to max, connected the can to the hose and then to the low side port, and started to fill it, i only put a little in it as the gauge was reading in the blue which i thought was odd, but the compressor was not coming on at all, so i stopped filling before it went into the red, i can detect no leaks, no broken connections, no blown fuses, i dont know how to manually make the compressor turn on, so looking for idea's suggestions or whatever help i can get, as i said the low pressure port reads as filled, but compressor will not engage
i have a 96 explorer EB 4.0L v6
