Rkownurko
- January 6, 2008
- North Wales, PA
- Explorer 97 Eddie Bauer
I have a 5.0 L 1997 Eddie Bauer.
I just bought it so have no history on the issue.
The A/C compressor clutch does not energize when the AC is turned on.
Things I have Checked.
1. Low Pressure Switch Good.
2. The WOT AC Relay is energizing in the engine box in the engine compartment.
3. I then checked for power at the relay on terminal 30 no power.
4. I then checked the fuse box in the car fuse location 18 fuse good but I had no power at the fuse.
5. If I jumper power from the battery to the terminal 87 the compressor comes on and AC works.
My Question is has anyone ever seen something like this?
Also does anyone have a wiring diagram for the AC and the main fuse box on a 1997 ford explorer.
I have one for my 2001 XLT but it does not match in colors and the wiring does not appear to be the same.
Thanks RFK
Thanks RFK
