bumpin this
Friday at 11am i am looking at a 93 mark 8.
What kind of gas milage does this thing get anyways?
it really depends on alot of things, basicly if the car has a good solid tune up and the tires are all aired up.. and the person driving shows a little prudence you can get 27-30MPG hiwqay.
IF the car has over 100K and has stock plugs and stock 02 sensors and if the person "has fun" driving the car, you can get 15-20MPG.
There is alot of leeway in mileage and it mostly is based on "driving habits".
With my car, W/373's going 65 with the AC off I can net 29-31MPG.
But I'm using a tune that I created, and I have to actually "TRY" not to have fun with the car.
The short of it...
If you drive right and the car is in a proper state of tune you can do very well 25-30 range
If you "drive it like you stole it" and most of the car is stock/plugs, wires and 02's then you could net as low as 15-20MPG.
Something you need to be aware of on the 93 4r70w.
AS soon as possible, before you put too many miles on the car, you NEED to flush the trans, and swap to mercron 5 trans fluid. This will go along way in keeping the torque convertor happy.
ALSO... get the upgraded 1-2 piston and spring along with a 98mark 8 transmission pan and filter.
The Transmission pan was improved in 98, adding capacity AND a sump to prevent the trans pump from being starved for fluid during corners and acceleration.
The pan, filter, gasket, piston and springs run around 150.00 if you get then from Max at
www.fivestarford.com {he does us well on parts}
When you test drive the car, if it will bark the tires on teh 1-2 shift at WOT, OR has a long delayed lagging shift. BOTH scenario's indicate a broken 1-2 spring an stuck or jammed piston.
Where is this car at?
if it is anywhere close to houston, I could probably take a look at it for you.
OR.. bring it to houston and we'll give it a once over with an "educated eye".
hope this helps
Tommy
