Splorer94
- August 23, 2004
- Mcdonough Georgia
- 1994 sport
ok i have a 94 explorer sport with the ohv 4.0. it has 120k miles on it and i bought it not to long ago. 3k miles rolled around and i changed the oil. i used 10/30 valvoline oil because it did have a good bit of miles and i used a motorcraft filter. i had no probems right... well a couple days later i crank the truck up and it has a slight knock only when you crank it up. when it sits at idle it doesn't knock. also it only knocks when the motor was cold or it sat for about 6 hours, and only when you crank it. well i looked in the owners manual and it said used 5/30 oil so i changed the oil again with 5/30 vavoline and motor craft filter. it still does it slightly..... so is that normal for this many miles?? (120k) its not a hard knock just a light knock when you crank it up...
