was28
- August 5, 2008
- '94 XLT
I have been troubleshooting the A/C system on my '94 Explorer XLT and think my problem is the compressor but would like to confirm this. With the engine running, the A/C on max and my gauges attached I am getting a vacuum on the low side and no pressure (zero) on the high side. I have bypassed the low pressure cut-off switch and the clutch is ingaged. With the engine stopped, I evacuated the system and pulled a vacuum to about 28 inches. After 6 hours the vacuum held, so I don't think I have a leak. I also replaced the accumulator and orfice tube. I'm thinking that the compressor is providing the suction but not the high pressure. I tried charging the system after I vacuumed it and found that the high side pressure went to about 30psi as long as R134A was flowing from the can. As soon as I stopped adding refrigerant, the high side pressure went back to zero. Am I right in changing the compressor? Thanks, Wayne
