J_C
- July 30, 2009
- Florence, KY
- 1998 XLT 4WD 4.0L SOHC
Grabbing and grinding is not due to the ABS fault from (any portion of it, including...) lack of rear speed sensor signal, is a different problem. Take the wheels off and examine the brakes.Hi, I know this is an old thread…
2000 Explorer ABS light on, code reads “wheel speed sensor rear center input circuit failure”, so I’d like to assume I just need to fix some sensors and circuits. However, when I cold start and use my brakes for a complete stop after starting, sometimes they grab and grind. Do you think that’s the same problem with the ABS, or is that a whole new problem with just needing to replace my brake pads?
thanks
