Air Pump Needed | Ford Explorer Forums - Serious Explorations
Air Pump Needed
boots
Cumbria England
1997 Explorer
Hi All,
My air suspension pump appears to has died. It would not turn off after a wading session during last weekends flooding and must have run for 2-3 hrs in total on the way to/from Manchester airport and now "nothing".
Having checked all live feeds and connections to the pump, they are all showing power etc and the leveling switch appears to work correctly. I have decided it must be the actual pump which will need to be removed to check its inards, so if I have a working spare it can be a swap rather than a strip down and clean to try and revive the old one.
If you have one for sale at reasonable cost, please let me know.
Cheers
Boots
have you tried moving the black post thing up and down to see if it activates? it just un hooks from the axel and push n pull, when you pull you should hear the air valve click to release the air and hear the air rush out and obviously pushing it would start the motor. gd luck
