zap_ingo
- November 22, 2003
- Ottawa, ON
- '96 XLT
Hi all...
I posted a thread some time ago about this and I got no answer, at that time I just let it run until now that I want to fix it.
I installed a remote starter/keyless entry in the truck. Starter works ok. Now, I needed to arm/disarm my factory alarm when I use the starter keyfob. Disarm works ok too, I connected the disarm trigger of the starter to a darkgreen/purple cable in the driver's door and it disarms when unlocking.
Now I wanted to arm the alarm when locking the doors with the keyfob, so I did some research and found that there's a trigger for setting the alarm in the drivers door, a yellow/black cable in the driver's door too. That worked ok except for one thing, the alarm goes off when the truck is started with the remote. The trigger in the starter module sets a pulse to disarm just before starting and then rearms 4 secs after start.
If I don't connect the yellow/black cable the truck starts with no problem and the alarm doesn't goes off, which is the expected behaviour, but it doen's arm the alarm when locking the doors.
Anyone knows how to connect this? Which cables to use to arm/disarm?
The starter is a ProStart Canadian model and has two neg (-) triggers for arm/disarm.
thanks in advance...
