Ya, I spent time reading on he forum. Some conflicting info, but I hope I got it. I also hope fuel will be fine, with no pain. I don't have a vac line from my little pulse corrector thingy to my manifold.
Today, I popped a hole thru my firewall and ran the wideband o2 line, and vac-boost line. I will tap my fuel rail for fuel pressure gauge when I take it off for the new injectors. I sure hope I don't mess up the threading part.
I'd like to get that wideband o2 gauge working just out of curiosity to see what my trucks currently doing for air-fuel ratio.
yea you lost mewe are using a stock fpr.i works by vac,high vac it opens and lowers fuel pressure,low vac or no vac it closes and increases fuel pressure.i didnt understand the pre blower or pre tb stuff either.after the charger where it mounts to the lower intake manifold should see vac and boost right?i would think everything on the other side(the intake side for the blades) would see nothing but vac.i would think at low rpm the air bypass would cause vac and when in high rpms the sc would be causing ALOT of vac.where does the boost gauge mount?i think this is where the stock fpr needs to mount,it needs vac and no vac(boost)
ok understand this a little better.i would think pre tb would see a little vac at idle and full vac at acceleration?sounds like a stock fpr works like a boost ref fpr,just increases fp in the rail when under boost(no vac) or acceleration
Yup, returnless. The fpr is in the gas tank, and on the rail there is some kind of pulse smoothing unit. I've read quite a bit about the returnless system. Lots of confusion around it.
Yep..all depends on what his gauge uses.they make many adapters so i would think a T or simpler would be best.taping the fuel rail i didnt even wanna think about.ill post a pic from my other cars with NOS setup,i luv NOS!! i built this motor for NOS but the one off 3800 build and sound,im all inhahaYou will be totally fine with fuel since you will be running a higher flowing pump and injectors. Most stock pumps will not be able to keep up with the required fuel flow needed by the supercharger. If the pump is too small then you will see fuel pressure start dropping off on the top end. Since you will be installing a bigger pump it will bypass more fuel while the engine doesn't need it because it is capable of flowing more fuel, but it will also be able to keep up with the fuel demands on the top end and not lose fuel pressure even up to redline.
If you aren't very skilled at tapping NPT pipe threads then I would take the rails to someone who is familiar with tapping threads. They can then tap the threads to screw the fitting in and also silver solder it in there so no leaks will occur. Your stock fuel rails are made from pretty thin metal so there isn't much material for the tapped threads to allow for a good seal to the fitting. Make sure that care is taken so the rail doesn't leak.
The other option is to run an QD tee adapter. Get a male QD on one side and a female on the other, with a 1/8" NPT port in the middle. This will connect between the stock fuel rail male quick disconnect and the female quick disconnect on the fuel supply line. Jegs or Summit should have these. EDIT: I just noticed that JD seems to have mentioned something similar in post#242. Something like THIS but you will have to check the O.D. size of your fuel rail male QD nipple.
If those prove to be too much then a third option would be to replace your stock hard plastic fuel rail crossover tube with a soft rubber fuel injection hose and tee into that with a tee that has two hose barb ends equal to the new soft fuel injection line you will be using and the other will have the 1/8" female NPT port you are looking for. Clamp it all down with some fuel injection clamps or some Oetiker clamps and you will be good to go.
Since I assume he is using an electronic FP gauge it most likely has a 1/8" NPT male thread on the end of the FP sensor itself. Not much that a trip to Jegs and maybe the hardware store cannot handle.
Yep..i have seen some with a male end,rare but who knows!!
It is the opposite of rare. Almost all of the electronic gauges pressure sensor are a male 1/8" NPT thread.
Yep ive seen alot of crap in my street racing days..ive been a all motor and NOS guy but ive seen most kits include a male to male adapter but seen then with just female.my charger has a male nipple for boost gauge for ecm stock on the side of it but the hole is not drilled in my lower plate for it to work.might drill it through when i re gasket match my lower mount to my IC
More guessing after reading. It looks like target a/f ratio would be around 12 to 13. 14 is pretty aggressive.
I can see how James is guessing when you send him a list of mods and expect him to magically hit the perfect air fuel ratio with a tune. Go on the safe side, and mileage isnt as good as it could be. Go too lean, and blow a clients motor up. I'd be afraid to make any tuning changes without a datalog and seeing the air/fuel ratio.
Wideband o2 is live. Calibration was a bit of a pain. On the innovate model, you have to pull the sensor out of the exhaust to calibrate it. Its done, and appears to be working.
Currently my A/F ratio is between 9 and 10.4. 10.4 is the ratio at WOT. 14 is optimum, correct?
I just tried moving on the leaner side using my SCT. Im interested to see if I can see a change on the gauge.
Also, I sent James a test data log file, just so he can confirm that he see's the Wideband O2 analog serial input going in to the laptop. At least this way, I can confirm logging is working before I have a vehicle that won't run, and James can't see whats happening.
