PDA1
- October 28, 2004
- PA
- '96 XLT
Do these pressure readings appear ok?
Here are the latest readings:
1rst situation......
Ambient temperature- 72
Center dashboard vent temperature- between 39 and 41
Windows all open
Vent fan speed- on the 2nd dot (that is- low speed)
A/C switch on MAX AC
Pressures- 175/20 (compressor off)
80/45 (compressor on)
2nd Situation.......
Engine RPM- 1500
Vent fan speed- full speed
Center dashboard vent temperature- between 41 and 42
Windows all closed
Pressures- 175/25 (compressor off)
3rd situation-
All the same as in "2nd situation" except A/C switch on AC (not MAX AC) and......
Pressures- 200/30 (compressor off)....I pretty sure of the Low side number. Seems strange doesn't it?
Thanks fellas.
Windows all open
Engine RPM- 1500
Windows all closed
3rd situation-
Thanks fellas.
