ratterrier
- November 24, 2001
- Livingston, NJ
- '96 XLT 2WD
Hi,
I just started draining the radiator in my '96 Explorer by attaching a tube to the outlet and opening the valve. It only trickled out so I figured maybe I needed to open the radiator cap and overflow container. The coolant came out slightly better, but still not much. I opened the valve as much as I could...it started squirting out of the valve threads, so I backed it off a bit.
At the rate it was going it would have taken about 1/2 hour to fill a gallon. Is there something I should be doing that I'm not aware of to drain the radiator faster...shouldn't opening the valve be enough ?? I don't need to do a complete flush.
Thanks,
Richard
Thanks,
Richard
