Dan Whitaker
One fast putty tat
- December 24, 2001
- Raytown MO (Kansas City suburb)
- No Mounty no more.
I did a search but did not find an answer.
I pulled the servo/actuator off this weekend as the heat had stopped working.
The shaft moved when I turned the temp control nob but it was kind of jerky in movement.
I also did the nail fix trick as the blend door is broke where they always break.
After re-installing the servo/actuator I had both normal & max A/C which I have not had since 2005 but still had no heat.
I went in the house frustrated & came back out later and started my Mounty and slowly turned the heat control nob & I could hear the blend door making a creaking noise. The A/C was still working so I turned the nob slowly all the way to hot and bam! I had heat again.
I turned the nob slowly back to cool turned the other nob to normal & max A/C and hot air was blowing out again.
Could the blend door servo/acuator be going out as well? My mounty has 183,000 on it & is a '97
