- September 6, 2006
- South Central PA
- 1994 Explorer
- Callsign
- yosty
I completely removed my rear sway bar and made up disconnects for the drivers side of the front sway bar. I could not believe how much it flexed after this!!! I will post pictures of the disconnects if I get around to taking pictures.
I have a question about the 3" body lifts for my '94 ex. I have done alot of searching on this. Is there anything other than the steering extension and the e-brake extension that will need to be extended cause of stretching it too tight? Like gas filler tubes, fuel lines, wires, and metal brake lines? It looks like that will be really tight lifting the body from the frame. I ordered the body lift 2 days ago from JcWhitney so it should be here next week.
One last question, I was looking at the james duff 2.5 inch susp. lift. I was wondering about the rear end lift. I already have a shackle lift that I welded up. What do you guys think would be ideal? An add a leaf or spring over axle? I know its to give you like 5 inches of lift in the rear ( which is probably way too high), but could I make a shorter shackle than stock to make not so high? I don't mind if it sits somewhat higher in the rear because I like the look of that, but too high in the rear just looks like crap! I always liked soa cause there isnt a bunch of stuff hanging there to get busted off. But if I used an add a leaf, would that help with body roll since I recycled that sway bar? Thanks guys, I am addicted to this website!
