Blacksheep Josh
Slinky+Escalator=Fun
- July 31, 2006
- Statesboro, GA
- '01 Ford Ranger, RIP 93 X
Okay, so I got my truck running again. No accessories are hooked up, no subs, no neons, no nothing. Completely "stock".
Battery cables are good. Grounds on engine/frame look good. Added another ground from the body to the battery, and added supplemental wiring from battery to fuse box.
Voltmeter (and everytime voltmeter bounces the headlights dim, so they're doing it together) bounces whenever I hit a bump in the road. If I go over a speedbump, the voltmeter will bounce and all the lights (headlights adn dash lights) will dim.
What can be causing this? So that when I hit a bump the system dims? As I stated before the grounds looks good... Nice and tight. Battery cable on teh positive side that connect the battery to starter has some corrosion but nothing to worry about. Wiring from battery to fusebox/solenoid looks fine and perfect.
So what else can I do/check? I'm outta ideas.
P.S. - Tomorrow I'll be adding extra grounding wire from alternator to battery.
