Bout Had It | Ford Explorer Forums - Serious Explorations
Bout Had It
fedexjockey
nashville, TN
96 XLT
My 96 xlt has a periodic miss. It has it at flat idle to full rpm......... I have cleaned the mass airflow sensor.....replaced plugs and wires........replaced egr valve...checked pcv....cleaned air filter......changed fuel filter......what else???
any advice would be appreciated before I drive it off a cliff......
Try cleaning the IAC and if that doesn't work, try replacing it..
1 step ahead
I changed the IAC about a year ago after it started making a whining sound............thx for the advice.....any other suggestions........
Does it seem to use more gas than it used to? If so I'd check the fuel pressure regulator.
