- November 6, 2000
- 2018 EX Sport Concept
Well think about it this way, if the problem is the pedal going to the floor, that MUST be caused by the hydraulics. The brake fluid is going SOMEwhere, and so if it's not leaking out of the system - it's moving within the system, to a void, likely an air pocket/air bubble.
When you do 'manual pump bleeding', are you doing it the 'right' way - the longest line (passenger rear) first for a pump or two, then the driver's side rear, then the passenger front, then the driver's front, then doing that until not even the tiniest air bubble comes out of any one line? Are you using clear hose to see the air bubbles come out? Are you bleeding into a container of brake fluid, however shallow, to block air going back up the line?
I'm still highly suspicious of the master cylinder, being it's the number one and usually only cause of a squishy pedal then going to the floor. If I had five reman/OE Motorcrafts go to the floor on me I'd look up aftermarket cylinders and see if one of them had a design that improved on the factory design, or what, if any, was the factory defect.
Have you looked up the part # to be sure what you're using is the correct part # for your vehicle? Many dealers will substitute parts and give you one that 'works' from an earlier or later year without having the slightest idea it would cause any issue.
Just looking at the Master Cylinder parts list for a 1995 Explorer on RockAuto shows that there are different master cylinders for models with/without cruise control and with/without a brake proportioning valve on the master cylinder. Perhaps the master cylinders you're using have been incorrect for your particular application, even if they would be 'correct' when going by the VIN, but that would assume a stock system, not modified in the way you have done.
