Gm's 8sp is a nice piece of kit too. incidentally ford partnered with GM on the development/design of the transmissions. the 10sp is an offshoot of the work from the GM 8sp. I find it interesting their choices in gear ratios and use. Ford seems to feel the ecoboost 3.5mill will benefit from the extra choices. I think another 10sp in is the works for paring up to the 2.7 mill.
That can't be true. It wouldn't make any sense to build a transmission with so much torque capability and only put it on a RWD.From what I was told, the 10 speeds are for rear wheel drive, 9 speed that GM partnered with Ford on is for FWD or AWD.
That's the info I got from inside. So far the 10 speed is in the f150, going to be in the SD, Mustang, expedition, navigator etc (all rwd). It all matches thus far.
Torque capability in fwd? When you have too much up front, you get major understeer and wheel hop. Nothing in the awd thus far needs that kind of trans (Explorer Sport, fusion sport etc). What else is there the is on the larger side that I didn't mention?
Taurus is gone, flex is gone, you won't see it in the escape, focus etc.
taurus isn't gone - what's the new continental made off of? There might be a redesign comeing down the road - should be by now.
ALso with FWD packaging you don't have nearly the room. the new 10sp trans is rather larger. GM does has an 8sp FWD transaxle - the nice thing being it has a counterpart that is put in the corvette.
I suspect you'll see a ford 8sp or like he said 9sp for the FWD based platforms and the 10sp for only the RWD. not so much because torque but as much about packaging.
I knew the flex was going away - still might get one.
but the taurus is going to get a platform revision is it not? where did you see that it wasn't? there is speculation that it won't but they still sell quite a bit of them and they are a fleet vehicle. However it also underpins the lincoln continental - so that has to either go another revision or die on the vine. which might happen either way.
is the new explorer platform going to be the ranger or is that still more speculation. I have heard rumblings that it will become that but not until some 2019 model year. And with that move to RWD again - which I would like.
otherwise the fusion is going to have to grow a bit more to make up the difference. There is talk of only the continental existing but I think that's a sales pipe dream
