heres' a fix for ya...i went to spray wd40 and i noticed a rubber pad covering, i believe what is the switch...as i went to turn away i noticed the wheel that rolls over it was coming apart...it wasn't the wheel...apparently this was a fix by the previous owner, electrical tape over the wheel....apparently the reason it was so intermittent was because it wore a hole in one spot of the tape...so, you guessed it...i put new electrical tape on and its fixed...the color match is perfect and i have plenty of tape...just so you know, i did tear apart the inside of the cab to see if i could remove the switch but no luck...no electrical..i'm thinking it's a negative bypass switch, when the switch is pushed it makes a ground to complete the circuit and the tape acts like a spacer to fill in the wear over the years...at least at nite i don't have to wait for the 40 minute automatic lite shut off before i can drive...
