nickorsi
- March 30, 2007
- Cumming,Ga
- 05 Mountaineer
I have a 98 Mountaineer and recently had to replace the Pass. side caliper, was sticking and the inner pad was gone.
I took it to a shop to replace but I'm noticing that when i brake it still pulls hard to the right, but I'm not feeling any drag or hearing anything like I did before.
What is the chance that the new caliper is bad? Or should I try replacing the driver side as well to see if that makes a difference. I've heard that you should replace both sides at the same time, but also didn't want to fix anything that wasn't broken.
