Jon_Herr
- November 5, 2000
- 2011 Ford F150 FX4
Oil Starvation
From details in the TSB, what usually happens is damage due to oil starvation.
This occurs because the plastic parts get in the oil pick-up and reduce oil flow to the engine.
The problem is progressive. The more plastic that falls in to the pan and clogs the pick-up the lower the pressure gets until it's low enough to damage the upper engine.
The pressure drops as oil is pumped through the crank and then up to the heads. The heads / camshafts get the least oil pressure and are the first to be damaged.
By the time the chains can be heard, some plastic has already dropped in to the pan.
