white96x
- September 4, 2002
- Rancho Cuc,Ca(home) SLO,Ca(school)
- 1997 E.B.
Camburg 6" Explorer Pics!!
Anyone running this kit? I've been doing some research and i'm probably gonna go through with it, a lot better engineered than the pro comp or fabtech spindles. Camburg uses a uni-ball upper A-arm with a 3.5" spindle, you could even op for a dual shock mount.. looks sweet.Anyways the only issues will be extended front brake lines, i need these custom made b/c as far as i know no one makes them, and another issue is larger front rotors i talked to Mike at Camburg and he said that the spindle doesn't run well with the smaller explorer rotor b/c it's designed for the ranger rotor which is larger...What do you guys think about all this??
