ronsdeal
- November 13, 2008
- Taylor, WI
- 98 XLT
98 5.0 AWD. Getting a P0420 code. After accessing the post cat sensors, one was hand tight, as I didn't need a socket. Pulled both post cat sensors, cleaned them, [they looked good before cleaning], and decided to swap bank 1 with bank 2.
I left the wiring the same. After resetting, The same cel code came back.
Did I do that right? or not? :thumbdwn:
I have a totaled 2000 X, 4.0, SOHC. So, with this info can we determine if the sensor or the cat is bad?
And regardless, are the sensors or the cat swapable/useable from my 2000?
To compound this, the bone yard guy is planning on comming over Wed/Thurs night to pick up and pay me for the 2000.
:exp:Hijacking my own thread... I had a dealer replace my bad 4405 transfer case from the 2000 with a good one I bought from a bone yard. Is it worth it for me to swap out my good one [on the vehicle that is getting salvaged] with the bad one I still have? And approximate used value and R&R time. [ iI know, alot of variables here.]
Thanks to all!!
Thanks to all!!
