Just a query really. As the front LH timing chain tensioner is exposed on the outside of the engine (mine being a nice flat grey one), what is stopping it just being unscrewed and having the new one (black one with 2 inch ext.) installed and torqued to 32ft lbs, with a new seal that i assume is included in the OOM12 KIT?
I mean this doesn't replace the lower intake seals or install the oil restricter, but replacing the tensioner must do some good? I understand how one would replace the lower intake seals, this doesn't seem that difficult from the various writeups, but where and how does this oil restricter go into it all?
The solution being sold on ebay for 650.00 does more than just install an OOM12 KIT, but is this needed, as the TSB recall in the US just suggests installing the kit, not replacing the chains etc?
My engine rattles a bit on start-up (say 2 seconds on cold start-up), warm start-up (say up to 5 minutes). However at operating temperature is doesn't rattle after the 5 minutes, obviouly between 2400-2600 revs within the 5 minutes it does rattle. What is the process of chain tensioner destruction, i have heard that as it gets worse the chain will rattle non-stop all the time? I assume mine is just starting then?
