motopsycho650
- February 20, 2009
- Denver, CO
- 1994 XLT
I just transplanted a '92 transmission into a '94 explorer XLT. No problems with anything except I have a check engine light that comes on about 5 seconds after I start the engine. I read the code with a flash reader, and the only code I get is a 536 "Brake On/Off Sensor."
I found the brake light switch on the brake pedal, and swapped it with the one from the '92. No change in the light. I am looking at my Haynes manual, and it shows a second brake switch in the cruise control wiring diagram.
The switch I found was on the brake pedal with a light green and a green w/ red wire going to it. The one I am looking for has a gray/yellow and a Black/yellow wire going to it (according to the diagram).
Any idea's where I might find the second switch/sensor?
