Austin Healey
- October 8, 2016
- Location
- Northern Virginia
- 1997 Ford Explorer XLT
Took in my '97 Explorer for emissions test the other day, and it flunked because the check engine light doesn't come on in self-test mode -- ie when the ignition is first turned on.
Here's what I've checked so far, based on other advice -- some from this forum, some scrounged elsewhere:
--gained access to instrument panel, checked bulb -- it's good (ie has continuity and resistance).
--swapped bulb and housing/connector w/ another one from the panel to see if it would work. No.
--plugged in code scanner to make sure OBD system was working, had power, etc. Yes.
--removed connector to main engine computer on firewall, checked to make sure pins and connectors appeared intact, clean, etc. No issues, no rust. I've owned the truck for approx 3 years, and this was the first time I unplugged the computer, so nobody's been messing with it. No change.
--also removed the big wiring connector on driver side of engine that connects to a bunch of engine sensors & misc. Checked pins, cleaned lightly w/ sandpaper, though they looked fine. No change.
--just for fun, cleaned the ground terminal for the computer connector, on firewall. Looked good, had no rust. No change.
The only other thing I can think of is to take apart the instrument panel and start tracing circuits to see if there's a poor soldered connection, etc. Any other suggestions?
I find it difficult to believe that the computer decided to fail ONLY on the circuit for the check engine light. All other warning lamps, indicators work fine, and the truck drives w/ no issues.
Thanks for any help.
