jlgray81
- January 10, 2014
- Columbia, Tn
- 2002 EB Explorer
A few weeks ago I had a small shift flare from 4th to 5th/OD..Got a fluid an filter change...still flared...so I started driving with OD off..Havent had any problems until the other night...Felt a kick in the tranny then my chime went off...looked at message center and it said 'check transmission' along with my OD light flashing...that lasted about a minute and the light quit flashing and the message center went back to normal
Had a guy check codes for me tonight..it through out p0743 torque converter clutch solenoid circuit electrical. Has anyone ever had this issue with this code? If so, what was the fix? I was told to replace the valve body and solenoids
