- November 29, 2000
- Location
- USA
- San Diego, PRofK
- 1994 XLT
Okay, I ran the codes several times and this is what I got:
Self-Test, engine off, key on;
566 Shift Solenoid Circuit Failure KOEO O
629 Torque Converter Clutch Solenoid Circuit Failure C
332 EGR Circuit Below Minimum Voltage C/O/R
542 Fuel Pump Circuit Open–PCM To Motor Ground C/O
538 Invalid Cylinder Balance Test Due To Throttle Movement During Test R or Insuffieient RPM change during Dynamic Response Test (engine run self-test
Self-Test, engine on;
3 (6cyl)
538 Invalid Cylinder Balance Test Due To Throttle Movement During Test R or Insuffieient RPM change during Dynamic Response Test (engine run self-test)
536 Brake On/Off Circuit Failure/Not Actuated During KOER C/R
After I cleared the memory, I got;
566
629
111 no codes found
I think the 566, 629 and 536 are all due to my Explorer having a GM 700R4 transmission that is not hooked into the computer. It also smells like its running a little rich. I hooked up a fuel pressure regulator and all pressures seem fine. Let it sit for ten minutes with no change.
So..........can you guys tell me what I need to fix to make these go away?
3 (6cyl)
566
629
111 no codes found
