joesilvia92
- August 30, 2010
- Bristol RI
- '96 XLT
I have a 96 xlt 4.0 ohv with 220000. So for the past week almost ive been loosing coolant pretty good, almost a gallon a day. Head gaskets were done around 170000. Im pulling misfires on cyl #1 over and over. The truck will mis on start up when at idle but not under load. Could these be related? Compression test came back good as did coolant pressure test. Theres no puddles on the ground, floor isnt wet like a blown heater core. Dont really know where to go from here. Coolant is leaking from somwhere onto the pass side end of the y pipe and also onto the oil filter, Are there any coolant hoses lower on the engine thant could be leaking? The heater control valve is about a year old and none of the heater hoses look as if their leaking. Im at a loss and need to fix asap as this is my only means of transportation. Any help would be greatly appricated.
