ryanw87
- June 24, 2010
- DE
- 95 XLT
I have a 95 XLT with only 98k.. cylinders are misfiring, was told it could possibly be a blown head gasket and/or cracked cylinder head, however im not getting the usual symptoms of those two problems. im assuming its an injector problem or a computer problem, more sure its a computer problem because every diagnostic tester i try connecting to the OBDII is not able to connect to the ecm. therefor, i am not able to get any readings necessary to diagnose anything. intake manifold gasket was replaced after i did a pressure test, replaced the coil pack and plug wires for the hell of it. it honestly drives OK, but occasionally when i really give it gas i can hear the cylinders knocking. the engine temp is perfect the entire time, im not losing any antifreeze. this seems to be a problem nobody is able to fix. ive been told the 95 was the cross year between OBDI and OBDII.. will i need a special adapter to get a reader to connect, or should i try replacing the computer?
