Me next in a couple of weeks. ... Man this is gonna suck.
Tim, been there and done that. I had the exact same problem. The only way to get the upper plenum (defrost) unit out is to pull the entire instrument panel. Yes, the entire instrument panel.
I remember pulling out the center console, disconnecting the steering shaft pinch bolt (make sure the wheel does not spin freely else clockspring damage). There are bolts up high just under the dark trim panel on top of the dash. Deactive the airbags. The firewall wire harness needs unbolting. There was one or two bolts coming from the firewall side into the dash that would really mess you up unless you knew it was there.
You have to buy a new plenum assembly. It was $267 list but picked up for $177 from Tousley. I went ahead and changed out the blend door actuators while I had the thing that far apart.
If you have the will and courage, please snap a picture of the entire dash laying across the front seats, it's quit a scene. Fortunate for me, there was a kind sole on this site that provided me all of the necessary service manual pages to do the job. I have those still and will share them with you if you PM me your email address.
Google your pn. Ford Parts Giant (and others) haveThe Defrost/Air Chamber Assembly (5L2Z18471AA) is no longer available for purchase. Can the electric motors on the 2006-2010 version of the part (7L2Z18471AA) be removed and replaced with the vacuum cylinder from the older part? Is there a way to bypass the vacuum cylinder entirely and wire the newer assembly directly to the dash control?
See my post on how to remove the part WITHOUT removing the dash! Once removed, I repaired the broken shaft end. My daughter still has that 2007 ExplorerThe Defrost/Air Chamber Assembly (5L2Z18471AA) is no longer available for purchase. Can the electric motors on the 2006-2010 version of the part (7L2Z18471AA) be removed and replaced with the vacuum cylinder from the older part? Is there a way to bypass the vacuum cylinder entirely and wire the newer assembly directly to the dash control?
They actually don't. I purchased from them and what appears to be another storefront run by the same folks. They told me three separate times they could ship it and then cancelled the order once it was placed.Google your pn. Ford Parts Giant (and others) have
this part in stock now! 5L2Z-18471-AA 5L2Z18471AA Genuine Ford Part
I buy parts from this site all the time. I have never had an issue with a part showing in stock not being delivered, but I guess there is a first time for everything. What year and model Ford Explorer are you having the issue with? I removed the one from my daughters 2007 XLT and fixed it with ingenuity and a short piece of coat hanger wire and some JB weld. It has been working like new for years now. (note: ensure you have a vacuum supply and that the little black and white one way Ford vacuum check valve (one engine side of firewall behind glove box area) is working properly - flows in one direction only. Remove your glove box and you can see the vacuum motor and the vacuum line that operates it. As I recall, you can see the end of the shaft that the blend door swings on. The small plastic ear where a control rod attaches was broken! I did not need the entire part, only a simple repair fix! GOOD LUCK!They actually don't. I purchased from them and what appears to be another storefront run by the same folks. They told me three separate times they could ship it and then cancelled the order once it was placed.
