crash594
- December 29, 2007
- 2005 XLT
Well I just done my first mod to my 2005 X I just purchased. I replaced the basic rearview mirror with a dimming unit. I will give the basics to the mod for others in the future. (I am not going to give wire color codes due to possible changes in models)
1) when you purchase it make sure it has plenty of of pig tail for splicing (mine was short and it was a pain in the rump)
2) removed overhead console
3) remove left windshield post cover
4)there are 3 wires a ground, a positive and the reverse cut out sense. the ground and the positive can be picked up right in the overhead from the map light. For the reverse sense you have to run a wire to the left window piller. There is a plug mounted there. The wiring for all optins are at that plug but the harness from there to the overhead does not. Find the needed wire and splice in. (hint; usually the color code on the mirror wire harness matches the needed wires fir splicing)
5) reinstall in reverse order.
I hope this helps someone in the future.
