Mitchs07explorer
- August 14, 2015
- Location
- Idaho
- Meridian, Idaho
- 97 XLT V8 AWD
07 XLT V6
so I'm currently in the middle of changing my water pump (all bolts out and cleaned up), after that I'm going to change my Cam position synchronizer and sensor. Changing out the cam synchronizer requires me to put piston #1 at TDC. The engine has 166k on it and sounds like people start to see a stretch in their timing chain even after only 100k miles. The Haynes manual recommends changing out the timing chain if there's more than a 10 degree difference on the crank pulley when the #1 is at TDC. What's the easiest way to determine if my chain has stretched too much, I felt like the Haynes manual was kind of vague in describing how to look for the problem. I want to make sure the cam synchronizer is installed correctly so I don't have to dig everything back out again. I was thinking about trying the pencil or screwdriver in the sparkplug hole trick to see if the zero on the pulley lines up as the pencil or screwdriver stops moving upward I just wasn't sure how accurate that method is. Any tips or advice would be greatly appreciated.
