MotorCityFats13
- January 25, 2015
- Points
- 58
- Flatrock MI
- 2007 Explorer XLT 4.0L
my rear right door worked sometimes when I first bought my truck used, over 3 months it totally stopped working. So I just got around to buying a new actuator and got installed... really easy job... the broken actuator feels sloppy like it is broken but I still can not lock/unlock my right rear door. So tested the left rear and right rear for signal... left side gets the +12/-12 pulse but the right rear does not... could this be something outside of a broken wire or connection issue... are the doors fused or have separate relays, no system I have ever messed around with was wired this way.... Also when you manually unlock any of those 3 doors while it is locked, opening the doors causes the theft system to start the honk honk response but the rear right does not,also all door ajar switches work... so i think the pin sensor in the mechanism is also dead but maybe a pigtail in the door/b-pillar is loose but the window functions properly.... has anybody ever had this problem?
