2014expl
- February 9, 2022
- ft pierce fl
- 2014 explorer xlt
Master window/mirror/lockout driver switch or passenger door switch operate. Problem was intermittent not now. The switches don't light up on ACC or running. Pulled master out of door, pin 1on plug(black wire good grd. No other pins had power. Pin ten had .35 volts on ACC. Pulled negative cable battery to reset stuff that worked on ACC but not when car was started. Could not repeat the reset. Any advice appreciated.
