jmiller427
- December 19, 2008
Okay so before y'all tell me to go do a search, I did.
Problem is you guys are so helpful and there was so much info, I now have more questions then answers.
Basically, I'm trying to figure out if I need to replace the outside handle, fix the spring, or the latch mechanism itself. I'm looking for the quickest fix, this truck does not get driven frequently.
Symptoms - door lock power mechanism broke at rivet, so I opened the door and reattached with bolt. But things never lined up well. Using the unlock button, the latch would sometime unlock all the way, other times not. When it did, I could only open from the outside - the inside handle won't open the door period, it's kind of stuck pulled out a little.
Now, the door won't unlock all the way at all, so I can't even get the door open.
Any help figuring out what I need to replace or fix would be greatly appreciated.
Thanks
Thanks
