LifeisaBeach
- September 26, 2008
- 2010 Ford Edge Sport
Howdy all. Having a problem with my driver's side door lock intermittently failing to unlock. I tried lubing it up which so far has worked out for the rear hatch as recommended in another thread, but the front door appears more complicated.
The problem is that it fails to unlock with the remote on occasion. When this happens, I can see the "pull stick" on the top of the door jiggle some and come up slightly, but not all the way. Using the key is futile... it feels as if there is some mechanical obstruction and it won't turn completely to the unlocked position. I was able to consistently replicate this problem by pulling the outside door handle while in a locked position, then trying to remote unlock it. I've only been able to unlock the door using the inside handle when this happens.
Now... as I mentioned, I lubed everything good but to little avail. However, while inspected the latch assembly, I saw a small spring sitting there with the hook on one end clearly not connected to anything. I saw no such spring on the other door so I decided to fish it out. The other end clearly had broken off from somewhere. Since I find it incredulous that it could have gotten in there from outside the car, I think it's a fair bet that it's part of the door's locking mechanism. Problem is... I'm not sure how I'm supposed to get to the whole lock assembly or remove it from inside the door.
I just decided to test out that door some more. It's less of a problem now, but I still run into an apparent obstruction when trying to use the key. I'm thinking that spring served to hold some part out of the way when the door was locked. *shrug* Anywho... any thoughts/ideas the situation? As I said, it seems less a problem now, but it's clearly not working quite like it should. Even when it does unlock, it seems to be resisting it slightly.
