90 linc. EFI 5.0 126,000 running motor with all electronics 3 wire hook-up,this is a non-HO motor. intake is perfect to install on you carb motor to get EFI
oil filter relocation kit
E/B auto rad. with cross over pipe
Elec. pusher cooling fan with fan control
75 e/b 302 c4 fresh re-build valve body needs cleaned, flywheel and T/C
75 dana 20 j-shift with shifter.
69 dana 20 T Shift
69 E/B 3 speed
75 E/B front and Rear drive shafts
69 E/B front and rear drive shafts
69 E/B 9 inch 3.50 gears
69 E/B dana 30 axle with drum brakes 3.50 gears
69 E/B frame no title
69 E/B manual steering box
after market Auto floor shifter
and i have a spare pan fill c-4 2wd trans to swap tail shafts with was being run in a derby car before it was pulled.
69 bronco speedo
and the are a few other parts i need to find
All parts are O/B/O plus shipping, but i'm not giving them away
69 dana 20 T Shift
69 E/B 3 speed
69 bronco speedo
