bizzs
- May 28, 2010
- Gibsonia Pennsylvania
- 2018 Ford Explorer XLT
I have a 2003 Explorer and does anyone have information on passing the drive cycle PCM test because the emissions tester is reading "not ready." I had 2 tests run and they both failed even after I drove 200 miles after the first test. My snap on solus indicates the p1000 code is gone and no other codes are found. The check engine light is not on and the truck runs like a champ. Firestone is blasting my 40 a pop to run the emissions tester computer and they will not put the PA state inspection sticker on until the emissions passes, even though the car past inspection with flying colors. Any data sheet available regarding cycling the computer would be appreciated.
Thanks
bizzs
Thanks
bizzs
